radar box jerky
Started by gwillis2, February 27, 2010, 08:17:40 PM
gwillis2
when i swich to full screen on the map display and back again i get a delay of upto 13 seconds before the map stabilises and runs normally again. Also the radar display seems to be jerky and not smooth.
I am running anrb sotware ver 2.01 purchased in october 2009
My computer is Intel atom 1.6 ghz 1 meg of ram
running on ms xp hme edition sp3
I have no other software running on this computer
is there any way i can resolve this?
You can download the latest version of the RB software which is V3.13.
Your PC is always going to struggle though I'd suggest.  That Atom 1.6 Ghz and only 1 Gb(?) of RAM isn't really up to the job.
However, you can try the following:
- Switch off 'Get Flights From RB Network'
- Reduce the refresh rate in File>Preferences>RadarBox>Screen Refresh - try 4000
- In the same Preferences screen, set the MyFlights timeout to 20 and 7 seconds.
Let us know how you get on.
gwillis2
thanks for the quick response allocator, but I thought when I purchased this packge and read the minimum requirements 128 mb ram, 400 mhz, i would be ok instead I am disapointed but I shal try your sugestion and see how it goes thank you.
