Reinstalled the 3D to new laptop and is gone to 2D
Started by Team Spirit, April 17, 2010, 05:35:24 PM
Team Spirit
Any ideas guys?
Having a right old session today :)
When the prog is installed it asks if I'd like to upgrade to 3D which I did yesterday so I say no - any ideas as to the best course from here ?
Cheers Dave.
PS having a bad hair day I reckon :)
Best regards Dave.
n8zrp
I experienced this for the second time today.  Installed Radarbox 4.03 to different PC again.
With the first incident, 3D mode would only activate on the on the installation that I first logged on to after I activated 3D mode.  If I would take my RadarBox receiver and connect it to a second PC with 4.03 installed and using the same account; I could use the Radarbox in 2D mode only however the Real Time data option I have is working.
I had to fill out the form at http://www.airnavsystems.com/support.html .  This generated a email response response from [email protected] in which the problem was fixed.
I'll have to do this again evidently as I've been doing alot of PC upgrades,etc lately and have run into this again.
I speculate that the 3D mode can only be activated on one installation at a time; hence the need to contact Tech Support every time you install on a different PC; evidently the Real-time mode option is not affected.
Could anyone from AirNavsystems confirm the issue with 3D only working on one PC at a time?  It would be nice to know that this indeed is the issue so I can determine which PC I want to semi-permanently install the Radarbox software on.
The 3D application is limited to 3 installs. If you try and install on more than 3 times you need to contact us or if your machine changes its hardware.
This due to licensing with 3D Map from Google.
