Reporter and Grids
Started by Canonjohns40D, April 27, 2010, 10:18:34 PM
Canonjohns40D
Hi i had earlier this evening aboout 1700 flights recorded on reporter and the grids showing 760 aircraft. About my normal recently.
Anyhow having been out for a while tonight i have just noted an amaziing 27968 logged on reporter and the grids show 118 aircraft. All my earlier log has gone and these 27 thousand have been generated between 21.06 and 22.00 tonight. All multiple entries for each of the 118 aircraft.
Any thoughts please?
john
Sounds like a database corruption problem maybe?  Have you made any updates to the database(s) outside of Radarbox - in SQLiteMaestro for example?
Canonjohns40D
Hi Tarbat
no I'm kinda scared to touch it at all. I take it i could deete the database as i have a copy backed up?
john
Canonjohns40D
Hi having run RB overnight as always i have logged 48500 plus aircraft. I have decided to shut down until i get home from work. Any advice on how to reset the log would be greatly appreciated.
John
Canonjohns40D
Bump
Aaarrrggggggghh!!!!!!! Hi Airnav anyone please can you tell me how to stop this errant log. Over 175000 logged today now and i only turned it on 10 minutes ago.
Please how do I reset the log or stop this.
John
Quote from: Canonjohns40D on April 28, 2010, 06:00:22 PMPlease how do I reset the log or stop this.
I'd suggest a reinstall, that will fix any data corruption issues.
abrad41
Canonjohn40D
Were you looking for empty log or something else.
Andy
Canonjohns40D
Hi the log is corrupted and I had hoped I wouldn't need to reinstall. However i'm goint o go for that option thanks for the help.
John
I think, if you delete the MyLog.db3 file Radarbox will create a new, empty one when it starts-up.
I might be wrong, but it's worth a try.  Probably best to just rename the file, to something like MyLog.bak, and see what happens when you startup Radarbox.
Canonjohns40D
Thanks Tarbat
I did a complete reinstall and it seems ok now. However I'll bear in mind your thoughts if required in the future, heres hoping it wont be necessary.
