Frustrated!!!
Started by 54901 - Jim, May 17, 2010, 10:10:50 AM
From my observations I very often see Cessna aircraft especially Ce525 and Ce560 with the nothing in the AT column.
At this time I have a Netjets Falcon 7X on my flights with only hex code and registration showing.  Looking at Database Explorer, all the info is there except AT.
54901 - Jim
When I get the blank ModeS records, the existing records with correct information are deleted from the NavData and MyLog databases.  The only evidence that something happened is that the ModeS info shows up (with no other aircraft data) in the MyLog database.
KOSH - Oshkosh, Wisconsin USA
54901 - Jim
Runway 31 ... since you're curious about this too ... please do a search in your MyLog data ... Show All/All Time.  Search all of your MyLog data with the filter AircraftTypeSmall = and leave the box blank.  Click the Filter key to see if you have any blank records on your machine.
Thanks!
Jim
#18
Yes quite a lot, take out USAF F15's etc drops it quite a bit but there are still a good amount, some because they are not on the database yet as they are so new.
Within the last week I have the following examples:
A8802F USA, Nothing in Airframes either
a3201b = N300JA
49D116 Czech, nothing in Airframes either
0D0431 = XA-FAS details were in Airframes but not the hex code, forwarded on
AA6CD2 = N771AV
4D203B = 9H-AFP
4CA852 nothing but on its delivery flight to Ryanair and not on Airframes
AE10EA - 2004 USCG
Edited to add, GAS now have 49D116 as OK-XLS
54901 - Jim
Jim, I didnt have anything deleted though, just no info in the first place.
54901 - Jim
Alan:
Take a blank record of your choosing and update the data using Database Explorer.  If that aircraft should return to your area before the bug is fixed, you should find that the data has been deleted from the NavData database.  I've updated hundreds of these records only to find that I was like a dog chasing his tail.
Jim
Jim,
I am fortunate in that I can spend all day at the computer and any I find with details missing I update them in database explorer, the majority of them being network flights but 3 or 4 a day in my flights.   I am maybe lucky but very few get over written, or maybe it is just that I am not noticing but I will keep an eye on it.
54901 - Jim
I'm retired with some time to play, too.  I don't use the network, so these are all locally generated flights that I like to keep track of.  This is not a high traffic area, plus my antenna needs to be located to a better position, but of the approximately 100 flights overhead in the past four hours, twelve of them have come up as blanks.
54901 - Jim
It appears that this problem has been resolved.  My list of blank records is gradually getting smaller.  Thank you for your prompt attention!
Jim
