Rsdarbox Repair - Info Needed
Started by CZUL, July 10, 2010, 08:42:41 PM
CZUL
My RB died this week, it no longer receives any flights off the antenna. How do I go about getting this repaired? What is the turn around time?
czul
http://www.airnavsystems.com/contact.html or
Recent forum posts have suggested that the turnround time is pretty short.
CZUL
Badger
It is worth checking the antenna and cable carefully.  I have seen a couple of "dead" ANRBs where the only problem was a damaged antenna cable.
rnsavage
I have a loose connection where the cable connects to the bottom of the antenna.
This can give the impression of a dead ANRB, but quick wiggle, and comes to life
Is there anywhere you can purchase a replacement btw (one that comes with the box)
Rick
CZUL
I've tested the RB with an external and back of the set antenna. I live very close to the airport. ADS-B equipped aircraft on approach do not show up as they used to. My SBS-1 running off the same antenna on the roof is showing traffic up to 150nm away.
