Most of my flights are displaying wrong destination info?
Started by Johnn, August 23, 2010, 11:48:29 PM
Johnn
Hi there, I have just turned the radar box on after 2 or 3 months and I have noticed alot of flights that have the routing reversed like, the aircraft is going to exeter when it says its going to madrid, It kind of looks like the oppersite of the to / from is always right?
hope some of it makes sence. I am using 3.06 Beta 2009
Thanks John
Johnn -
Hi John - I do recommend you upgrade to the latest version, but that won't make any difference to the routing problems. There's lots of discussion about that on other threads at the moment. It's a work in progress...
Johnn
Thanks for the reply Rod, Does anyone know how I can upgrade to the latest version and still keep my polar diagram?
Johnn -
John - you probably know that you should back up Navdata.db3 and MyLog.db3 to keep your database and log intact. To preserve your polar diagram, back up D012.dat as well.
Once you have installed the latest software, copy the three backups into the new installation Data folder and all should be well.
