Hide Small Airports
Started by andrewarles, August 06, 2010, 09:59:22 PM
andrewarles
Hi everyone,
There is a menu item "Hide Small Airports".  What is the definition of a small airport, and can they be changed by the user.
Andrew
16 NM SSW of LFMV (Avignon)
27 NM NW of LFML (Marseille)
Arles, France.
They can't be changed, and this only applies to airports in the US, we don't have this data for the rest of the world.
andrewarles
OK
If we gave this data to you in the required format, would you be able to update the db.
Rgds
Andrew
Arles, France.
Quote from: AirNav Support on August 06, 2010, 11:02:17 PM
...this only applies to airports in the US, we don't have this data for the rest of the world.
Ah, that's why nothing is happening to all the small Airfields in my closer Region, if I check or uncheck this particular Option.
anorak
I think you could create your own map with the particular airfields on, etc, that you want and then save it with a specific name.  Good luck,   Dave.
Dave. Exmoor, North Devon.
andrewarles
Hi AirNav,
Quote from: andrewarles on August 06, 2010, 11:45:26 PM
OK
Rgds
Andrew
Could this be a possible solution for users outside the US?
Arles, France.
Its data which stored in the map data and navdata so needs to be in that format. We hope they will get further data soon on the rest of the world.
Chris11
I can supply the data for my end of the world if required
