approach
Started by rashers, October 03, 2010, 10:33:45 AM
rashers
hi lads can anyone help with this when plane just about to land still very high on approach and also when landed its stuck on approach for two minutes even its on the ground is there a settiig i can go into to stop this problem thanks
Quote from: rashers on October 03, 2010, 10:33:45 AMhi lads can anyone help with this when plane just about to land still very high on approach and also when landed its stuck on approach for two minutes even its on the ground is there a settiig i can go into to stop this problem thanks
It would help to know:
how high it is ?
where is it on approach to ?
It sounds like you are looking at an altitude unadjusted for QNH and/or an airfield considerably above sea level.
Check you timeout settings on Preferences.  I use 17/43 for local aircraft.  SO, after 17s aircraft timeout, and after a total of 1 minute they dissapear from the map.
rashers
sorry dave the airport shannon co clare also tarbat i will try them setting on time out thanks for that
