My honest review of the DPD Productions ADS-B Antenna
Started by CYYZGUY, May 05, 2011, 12:16:06 PM
CYYZGUY
After waiting several weeks to receive the antenna from Dave at DPD, I finally got it and unpacked it.  As usual his packaging is superb and the box was sealed very well.  In a matter of minutes I attached it to my balcony, up 7 floors and ran the cable inside to the airnav box.
The Difference was noticeable right away.  Not only did I receive more aircraft...(Both Mode-S and ADS-B), the polar diagram started increasing in size right away.  My range was extended dramatically!  One thing I noticed was that the amount of ADS-B aircraft increased within the same range as I had before.  Meaning I was not picking up some ADS-B aircraft that were right under my nose.  Having it tuned to 1090 Mhz seems to be the key!
I also find that the movement of aircraft on my screen now seem more "fluid" as the signal is being received much stronger.
Highly recommended!
Jason
40" LED Monitor
40" LED Monitor
Canonjohns40D
HI Jason I ordered one and I have to fully agree with you on all aspects; from the ease of ordering, delivery service, packaging, the construction and results. It's superb bit of kit.
John
