trouble with vista
Started by charlie, June 02, 2011, 06:23:02 PM
charlie
Hello
Help needed please.
I have just changed the laptop which I run my airnav box on.
Problem is that everytime I shut it down (proper way) when I start it up again it freezes on the start screen.  I press cancel and the program shuts down.
I then have to reload the program and it then works fine.
I am running Vista Home Premium.
Any ideas on how to solve.
I am away this weekend so if you answer I will not respond until Sunday at least.
Thank you for all your help.
Vista is totaly updated and I am using AVG free 2011 and Zonealarm
Again thanks for any help
Charlie
anorak
Can you find were the prog has been loaded to, IE   C-prog-?
Dave. Exmoor, North Devon.
I take it you have set up AVG to ignore the Airnav folder and have avoided installing Airnav in the default program files location?
charlie
Yes I have avoided putting airnav in the default program.
I have put in another and it still works once but after shutting down and restarting it starts but when you press start (in the screen that says 'account' and 'cancel' it stops dead.  The only way out is to cancel.
Any more idea's.   It's strange that it starts once but then stops.  It worked great on my old windows xp laptop but not on vista.
Are there any patches for vista?
Help again
Charlie
When you exit RadarBox, run the task manager and check that RadarBox is not running in the background (or failed to exit fully).
Otherwise we haven't heard of this. We assume you are also running RadarBox as admin?
charlie
Just got back from a great weekend camping with a little bit of ham radio but back to the airnav box.
It's not running in the back ground but when I opened the icon and pressed run as admin it now works fine.
Charlie
