Radarbox 3D
Started by satbopper, August 03, 2011, 11:36:17 AM
satbopper
Hello,
I just recently bought the 3d radarbox,apart from the automatic sending
of the logfiles it works smoothly.
There is one thing i found out,if radarbox is running and i start Photoshop,
radarbox will crash
Maybe something for the developers
Greetings
Ronald
Ronald
I use Photoshop and dont have any problems.
Chris11
Sounds like a Win7 problem.
My Radarbox was perfect on XP - then I upgraded to Win 7 and now when I install new software as an admin RB crashes during the installation.
May Bill will sort it out in Win8
satbopper,
Whats your computer specs? and what 3D settings do you have on in RadarBox 3d?
Dean
My Win 7 64 bit does the same. If I open Radarbox after Photoshop (CS5) then there are no issues. It's not a low spec machine Intel i7 CPU & 6 GB RAM.
It does it with 2d as well as 3d running.
Dean
Where do you have radarbox installed on the computer/
satbopper
Ok here a reply from me
My computer specs are the same as Deans
intel i7 6gb ram win 7 64
i installed radarbox in program files(x86),maybe thats an issue
my 3d settings are hardware detected flights maximum and network flights minimum
my resolution is 1920x1080,videocard is an ati radeon 5700
satbopper
i forgott to tell you that i connected radarbox to acars 170rc3 for the acars messages
the acars program is running on a different machine
Satbopper/Dean
Installing onto the default setting c:\programfiles\airnav casuses problems from Vista onwards due to the virtual store.  Try uninstalling and re-installing into somewhere like c:\Airnav and see if it makes a difference
satbopper
Ok Alan
I will try that but if i save the data dir first and put it back to the new installed
environment,would that be enough to keep my settings and data
I couldnt say for sure.  It will for Mylog and navdata but I dont know about the settings.
Dean
Mine is installed at:
"C:\AirNav RadarBox\ANRB.exe" so unlikely to be a problem. Not even saying it's ANRB that has the fault - it could equally be Photoshop causing the issue. I can live with it but any further suggestions welcomed.
satbopper
your right Dean
i did a fresh install to C:\Airnvav radarbox,i recovered the data and back online
As a ham amateur i have several programs running on my computer,together
with anrb no problem
Only Photoshop will crash anrb
So what is wisdom,is it win7,anrb or photoshop.
There is one thing sure that an install in C:\Airnvav radarbox is better
then the default install
What version of photoshop are you using? We wonder whether they are sharing something (dls, ports etc..)
Dean
CS5 64 bit - latest update but it's always done it. CS5 doesn't have anything hardware wise that the reso of the PC doesn't also use. Be happy to send any screen grabs etc etc if you tell me what & where to find it etc.
