a380-a388
Started by jasper37, January 01, 2012, 10:51:17 AM
jasper37
 Emirates show A388 others show A380
can anybody help me to manually update this untill this is sorted in updated version
many thx again for previous replys
and happy new yr to all
Happy New Year Jasper,
To manually update go to top left of Airnav screen, click on file and on the drop down list click on Database explorer.  When the box opens on the middle of the screen change Select Table to Aircraft.  In the box yo the bottom Text to find, type in the registration of the aircraft concerned, Condition to By and Field to AR.  Click Find and the details should come up on a line at the top of the main box.
Ckick on the cell you want to change AT, it will turn blue,click on edit cell that will allow you to make the change you want, make the required change then click anywhere in the main box to save the change.  You can then move on to the next aircraft doing the same.
Alternitivley at step one you can put A380 in the Text to Find box, Condition By again and Field this time will be AT and any A380 will be found
jasper37
Many thx RUNWAY31
and a Happy New Year to you and your family
rgds Jasper
Chris11
... and the third alternative is to right click the aircraft when you see it in your active flight list and select "Locate Mode S code in Database Explorer"
To change the content of a marked cell in database explorer you also can use the "F2"-Key. This is in my opinion much more comfortable then using the mouse and click on edit. Especially if you need to amend more then one airframe in the row.
