Airnax Box not connecting
Started by Michael James Flannery, April 06, 2012, 03:39:26 PM
I am unable to connect my airnav box to the hardware or network, I have reloaded drivers and uninstalled and re installed but still no luck.
I have also reconnected and disconnected but still the box will not connect, any ideas please.
Many thanks
Jim Flannery
Jim,
What vesrion of Airnav and Windows are you using?
Thanks for your reply Alan, Airnav 2010 3.13 and windows vista.
Jim
Jim,
Can I confirm you are getting no aircraft at all either on your own Myflights or throught the Network?
If so on my flights bottom left corner, do you have Process Harware flights ticked and on Network do you have Get flights from Radarbox Network ticked?
Budgie
What's happening on the Airnav RadarBox, what lights do you see and what are they doing?
Also, under the "Process Hardware Fights" tick box, what colour is the square next to where it says "Hardware" and does it say "Connected" or "Not Connected" next to this?
ShaggyPara
Give us some details, what do you mean by not connecting?
bearcat
If your running Vista or W7 try right cliking the ANRB icon and select "Run as Administrator"
Thanks to all that replied I had a faulty USB connector which I have now replaced, I am getting my flights again, but I have been unable to get a network connection for the last 24 hours, has anyboby else suffered this and what can I do to rectify.
Many thanks
Jim.
The network has been up all day Jim with no problems today,  Check the Get Network flights checkbox is ticked.
Hi Alan
The get network box has been ticked and is yellow, but this still does not connect ?
Jim
Sorry Jim,
I have no idea.  If you have Get Radatbox network ticked and have am internet connection you should have no problems.  i take it was OK before your cable problem.
Maybe try restarting to see if that helps
Thanks Alan,
Yes all was OK before the cable problem, I have tried restarting on a few occasions, but I Will give it another go.
I do appreciate all your help.
Best regards
Jim.
Hi Alan
Thanks for your advice I reloaded programme and found a Firewall on my computer was blocking the Network connection, now back on line for my flights and network movements, what a relief, its nearly three days now without the network connection how have i survived ?.
Best regards
Jim.
Glad you got it working Jim and will keep mind of the firewall issue.
