Can't find "Screen Shot" folder in "AirNav Radarbox" main folder
Started by Birdie, June 18, 2012, 08:37:50 AM
Birdie
I have been saving numerous screen shots in the default location "Screen Shot" under the "AirNav RadarBox" main folder.
However, when I use Windows Explorer to view the folders, i cant locate "Screen Shot" folder.
Could "Screen Shot" folder be hidden somewhere ?
Hi Birdie
Screen Shots will be AirNav RadarBox folder. If you've got Vista or Windows 7 and you've followed the installation advice on the forum it should be easy to find. I suspect, though, that you've installed using the default installation setting, and the folder is in the Virtual Store.
You may need to explore that - in the Users folder - to find the Screen Shots folder.
It may help to do another Screen Shot, and when RadarBox asks, tell it to open the picture. If you then use "Save As", your viewing program should show you the path to the folder that the picture is in.
Hope that helps
Birdie
Thanks Rod,
I will try that.
I wanted to show Tech Support how much the "Equator" software upgrade have improved my receptions.
But I can't find all the Screen Shots I saved.
cheers,
Birdie
pjm
Quote from: RodBearden on June 18, 2012, 09:01:21 AM
Hi Birdie
I've installed in Windows 7 64 bit using the default directories.
My screenshots are where I'd expect them:
C:\Program Files (x86)\AirNav Systems\AirNav RadarBox\Screen Shots
actually - if you click your mouse button in the folder name where you are saving the screenshots (per the arrow in this screen shot
you will see the actual directory where radarbox is saving them
Birdie
thanks Rod,
I open the file and did a "save as". I found the folder.
