Column Widths
Started by bbrasmussen, November 24, 2012, 07:50:50 PM
bbrasmussen
Is there any way to resize/customize column widths? Almost all of them are way too wide. This results in difficulty following and reading the data. In my area there aren't as many ADS-B aircraft, so I rely a lot on the Mode S data in text form.
Thanks,
Brandon
near KSLC
Brandon,
You can't resize the column widths but if you go into File - Preferences, you can choose which columns you want to have by ticking/unticking the appropriate boxes.
bbrasmussen
Thanks! That's much easier to read. I guess I should have figured that out on my own.
No problem. Glad to be of help.
