Blank pictures
Started by knight01, March 08, 2013, 01:26:34 PM
knight01
How do I stop blank JPG aircraft pictures from downloading to the photos folder, when there are pictures available on Airliners.net.  The use of planespotters.net for picture has really messed up the photos folder and aircraft photos in the Radarbox client.
I preferred it when there was no picture available message and these blanks were not created in the pictures folder.
Will these blanks get overwritten when there's a photo available on planespotters.net.
#1
The blank problem was reported as fixed a couple of weeks ago and blanks have not been being downloaded since.  If you delete the blanks that you have the photos will be downloaded next time the aircraft is picked up.
To aid you try this as advised by Niklas on 17th February
Open Explorer, go to the Photo folder (located: \Radarbox\Data\Photo), change view into details. Then sort on the Size column, select all photos that are 1 KB, then delete them.
The correct photo will then populate the next time.
