Is KLM changing their Flight ID's?
Started by CYYZGUY, October 05, 2013, 05:51:11 PM
CYYZGUY
Lately I have had many KLM flights with very simple Flight ID's
I have KML47 on my screen right now, with of couse NO route info.
I have had KLM32 as well as others lately.
Can anyone explain?
regards,
40" LED Monitor
40" LED Monitor
Jason,
Have you maybe thought that it is quite simply because the route wasnt in the database.  I have now entered it EHAM-KORD.   It would have been appropriate to put this post in the d/b update thread same as normal.
They are in the d/b. It's the leading '0' bug in action. Both are there but under KLM047 and KLM032.
CYYZGUY
Alan, I did not feel it was appropriate to be in the database thread as I was asking a new question.
A few days ago I posted another KLM flight and you said.......
KLM32 appears to be KLM691 using KLM32 as its callsign and routes CYYZ-EHAM.
I was simply asking if anyone knew why the flight ID's are changing.
regards,
40" LED Monitor
40" LED Monitor
#4
Jason,
I dont believe they are just I didnt have them in the d/b, Can you also pass the flight ID's of the many other KLM flight you have seen with no route and I will add then in as well.
Alan,
See reply #2 above. It will probably continue to occur .
Ian,  Have checked while some have leading zeros, they are also in without the zero.  I have removed all the one with the leading zero from the d/b.
