Problem with updating Route d/b
Started by John Racars, November 13, 2013, 03:53:33 PM
John Racars
Good afternoon All,
tryed to update my route database this afternoon, following happend:
Log:
15:39:02: Update Started.
15:39:02: Checking Server for Updates.
15:39:03: Invalid Data Received from Server. Update Aborted.
What is going wrong here?
All updates where going well until sofar; I did not change preferences since than.
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
The server was a bit unstable earlier which would have caused some corruption in any data downloads. It should be ok now or very soon, try updating in an hour.
Northern Watch
Hi Airnav Support
Just tried to do an update and had the same as John.  I take it that you are still having stability problems.  Please can you update us on situation.
NW
John Racars
problem here looks not solved until sofar. Still the same log-messages.
BTW: a verry high number of flights with NO route-info while present in the d/b.
13 NM East of EHAM
ANRB:
John Racars
#4
Still the same problem at this moment and a growing number of flights not showing info while in the d/b.
It is not to do looking up routes not show and still in the d/b at the moment I think. At this moment many routes not showing route-info on the (my) screen but are in the d/b present. How is that possible?
Quote from: AirNav Support
Reply #1 on: Today at 04:17:14 pm ยป
this log is from 7:37, verry much later than one hour after 4:17
19:37:38: Update Started.
19:37:38: Checking Server for Updates.
19:37:39: Invalid Data Received from Server. Update Aborted.
What is the state of affairs if I may ask?
13 NM East of EHAM
ANRB:
There are still issues with the server which are causing the network and other functions to go offline.
John Racars
Thank you verry much. Hope you will be so kind to inform this forum when the problems are solved.
13 NM East of EHAM
ANRB:
Michel
Looks like it's up and running again. My RB is picking up flight ID's from Airnav d/b again.
Yes the network is back up and running
