libhomeradar
Started by capetown, February 14, 2014, 03:39:39 PM
capetown
can anyone help, I recently had a comp. fault and lost winsend2 and acedit from libhomeradar tried to get in touch with libhome but no answer would appreciate if any one could download some info how to reclaim same two programmes and how to install properly, apologies as I know this is not airnav material but it works with same, many thanks Ronnie hynd
I haven't used winsend for ages. Found an installation on my PC but not the original zip file. Seems that libhomeradar has ceased support of winsend. I never used acedit. Now I#m using glightshare to feed the database. For accessing the information if needed I use the website.
Did some testing: seems that winsend 2.4.7 just needs the files in the folder. If you want you can contact me by pm with your mail address in it and i'll send you the files in a .rar archive. Do you have a copy of your local winsend database? If not there might be a problem.
capetown
many thanks ingo, I do not think it will work but worth a try. [email protected]
