Screen display fails to save
Started by MIKE.UTD, June 11, 2014, 10:18:51 AM
MIKE.UTD
Since the last update my screen display every month fails to save and the program loads like a new install.
Any ideas ?
Means it takes some time to adjust it to the way I want it to be displayed.
Thanks.
Mike.
Mike,
Before closing down try going into Window>Record Desktop. Then confirm you want to 'Save Changes' and see what happens. Strangely enough, I used to have to do that before shutting down but since the latest update I haven't had to.
MIKE.UTD
Thanks for the help, have done that in the past but when I press restore desktop it just all goes grey.
Will try again.
Mike.
Judwin45
I have a similar problem.
I normally run my RadarBox on my desktop PC. On the occasions when i disconnect and use it on my laptop and then reconnect to my PC I get the world map and have to reset everything to my local map and preferences. I am sure it never used to be that way.
Keith
5 miles south of EGDY
