Windows 8 Drivers Don't Install
Started by claya1, April 16, 2014, 03:48:00 PM
claya1
After downloading the drivers for Windows 8, I get the following message when trying to install:
"The hash for the file is not present in the specified catalog file.  The file is likely corrupt or the victim of tampering."
Any help would be appreciated.  Thanks!
claya1
Thanks I've just done that. I can't believe that other people wouldn't also be having this problem, so I must be missing something.
Others have but Airnav are the only ones that can sort the problem
Burnley
I've just started to get this after re installing my computer.  Windows 8.1 Pro and it says the hash for the file is missing or something when I try to update the driver and pointing it to the correct folder.
Contact [email protected] they are the only ones who can assist
tommyg
Guys.
The notes that Airnav put out re WIN8.1 are not quite correct. You need to get your recovery key first before you can get to item 7 to change one of the settings. AiRNAV I believe are chasing MS to get the problem resolved. PM me if you want and I will try and give you the correct process.
tommyg
Tommyg
