Screens gone
Started by John Racars, November 07, 2014, 02:01:15 PM
John Racars
Hi All,
my cards are suddenly gone.
See screenshot below what I get to see since I restarted RB.
Any help will be verry welcome.
Thank you in advance!
John
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
You appear to be in full screen mode.  Try pressing ESC and give a few moments to return.
John Racars
Thank you Alan!
Does not help. Still gray mapscreen.
John
13 NM East of EHAM
ANRB:
#3
ok, try pressing the map view button. Or the split view and then the Map View button.
John Racars
Thanks again Alan!
Nothing helps. No map on the right side of the interface.
A gray surface in stead of the place where normaly the chard should be apear.
Kind Regards, John
13 NM East of EHAM
ANRB:
I presume you have closed down and restarted John.  Also try Map/Set Map to and try World
Other than that I am out of ideas and suggest you contact [email protected] for assistance
John Racars
Does not help as well.
I will call support.
13 NM East of EHAM
ANRB:
John Racars
Hi All,
maybe it should be an idea to re-install the total version of RB?
I tryed the update; does not help.
Suggestions will be still welcome.
Kind Regards, John
13 NM East of EHAM
ANRB:
Try the full install and see if it helps.
John Racars
Thank you Alan.
Where can I find the full version of 5.00.071?
Reg John
13 NM East of EHAM
ANRB:
Hawkeye
Hi John,
According to the Support page, download for latest version can be found at:-
http://www.airnavsystems.com/download/ANRB/ANRB50071Setup.exe
Found it helpful to bookmark the Airnav support home page as I could never remember where  to find updates, useful info etc.
http://www.airnavsystems.com/RadarBox/support.html and
Hope you soon get to the bottom of your problem .
Syd
John Racars
Hi Syd,
thank you for the links; I take over your suggestions about the bookmarks!
Re-installing RB solved the problem. All like to be work as normal again.
Kind Regards, John
13 NM East of EHAM
ANRB:
Glad its now OK John.  For the support page, if you look to the left of this page you will see RadarBox  on a green background, click on it and on the page that opens up you will see Support around 4th line down. Click on it and the page opens to various links for RB versions, Drivers etc.
John Racars
Thank you verry much Alan! I highly appreciate your help and tips as well!!!
Kind Regards, John
13 NM East of EHAM
ANRB:
