Navdata File
Started by NB, December 10, 2015, 09:35:53 PM
NB
Hi again!
I have been checking my installation and noticed that in the Data folder I have several navdata.db3 files, corresponding to the updates I make to the database. Every file is roughly 79MB. I suppose something is wrong, not to mention the space in the disk it occupies...how should I proceed? which file is the program currently using?
thanks!
There should be 10 Navdata.db3 files, one is downloaded each time you update and the 10th one going by date is deleted each time you update.  The active one is the one with no date.  You can safely delete the others if space is at a premium or you but remember that each time you download you will need to delete the previous one.
NB
thanks for the fast reply!
