Ruler
Started by FACTflights, December 19, 2015, 09:01:25 AM
FACTflights
Hi all,
You know what would be realy nice in a future upgrade ?
A ruler that can be stretched across the map to measure distances.
John
ZS1AGH
No HF antennae at the moment.
#1
Hi John,
I don't know if you're already aware, if you go into Preferences, you can set radar rings to either centred on Home, or at centre of map then by zooming in and out it is possible to use these as a rather crude measuring tool in nautical miles (1 NM equal to 1.15 Imperial Statute mile).    If centred on home you can work out how far away from you a A/C is, and this line if sight distance is also shown in one of the columns.   If I'm trying to teach granny to suck eggs, I apologise, but moving the 'floating' rings is how I guestimate distances - and fairly accurately +/- 5% usually.   By zooming in and out you can also use these rings to measure line of sight land distances.    HTH   Jon
if you click on an ADSB aircraft and scroll along the grid to the far end it shows you the range and bearing from your location
FACTflights
Yes, I know that, and also use those methods.
I am just being lazy, wanted to measure the distance between two objects, and thought about a CAD programme that has a pencil line ruler that can drag across the page.
John
ZS1AGH
