Changing over from SBS
Started by abrad41, May 22, 2008, 06:25:40 PM
abrad41
Hello to you all
I am new to this site, so forgive me if ask some silly questions.
I am a SBS1 user and would like some info on changing over to use the radbox system.
Could I use my antenna I have now, which is the BS1100 on a 10ft Pole above the house.
Please help
Andy  Norfolk
Yes you need a SMA-BNC convertor to get it connected to the RadarBox. They are cheap about £5.
#2
Hi Andy,
Welcome to the forum :-)
I use the BS1100 as I got this when I was using the SBS-1.  It works a treat with RadarBox with the adaptor mentioned.  There is a thread about this and I'll post the link when I find it.
Edit:
Here's the link:
http://www.airnavsystems.com/forum/index.php?topic=634.0
By the way, there are no silly questions so ask away!  See the FAQ section for lots of good information:
http://www.airnavsystems.com/forum/index.php?board=2.0
abrad41
Thank you very much for your advice, I am very fed up with the backup you get from Kinetic or ML&S. I have been waiting for this new Ethernet Module - Its well late and there is no comunication.
Could I have some comments on the radar box and is it better than the SBS1
Thank you
Andy
"I am very fed up with the backup you get from Kinetic or ML&S"
I assume you mean you are fedup with them not us :) Of course RadarBox is better, have a look at the comparison:
http://www.airnavsystems.com/download/anrb/AirNav%20RadarBox%20vs%20Competition.pdf
abrad41
yes I am very fedup with them not you, just would like to now a lot more about radarbox and make sure i am not jumpping out of the frying pan, But i am very very interested in changing if the only thing I have got to get is a adapter.
Andy
Andy,
Of course it's better!
Works right out of the box, no mucking around adding dozens of 3rd party add-ons to get a decent picture then there is the Network - fantastic.
Just read through those FAQ's for all the good info.  I was an SBS-1 user for a year until I got my RadarBox, now the SBS-1 just sits in the corner gathering dust.
abrad41
abrad41
Could I please ask some questions.
1) My sbs1 is in my loft - could I still use my USB extender from the loft to computer down stairs.
2) Can I use radarbox over a home network and use on more than one computer.
3) If I was at a differant location in the world - could I look at my data (Radarbox) over the internet.
Thanks for the help
Andy
#9
Quote from: abrad41 on May 23, 2008, 07:22:41 AM
Andy, I use a USB extender - the type that has standard CAT 5 network cable giving you up to 45 m extension - with no problem at all.  The advantage of RadarBox is that its powered wia the USB lead, whereas some SBS-1 units require a seperate power supply.
Quote
In a word - no.  The RadarBox receiver must be connected to the computer that is running the RadarBox software.  This also applies for you to receive AirNav Network data.  RadarBox isn't a network device, hence the need for direct USB connection.  I modified my SBS-1 with the Ethernet module mod that came out about 8 months ago.  It worked very well as I could access the SBS-1 wirelessly on my network, however, I didn't really use this facility very often.
You can use Radarbox on as many computers as you like, but you will only see aircraft when the Radarbox hardware is plugged into that computer.
You can run the RadarBox software without the hardware to view recordings though.  You could download RadarBox V1.5 now and visit the RadarBox Utilities website and download recordings to play back.  This will give you a good idea of what you will see.
You can download the RadarBox V1.5 software from here:
And the recordings (2) are available here:
http://www.airnavutilities.co.uk/
Quote
Again, no.  However, as RadarBox is so portable, it's easy to take it with you to view live data picked up by the RadarBox receiver and antenna.  If you have internet access, say in a hotel, then you will be able to see the Network data so you'll probably be able to see your home area anyway.
I'm sure you could use one of the various remote access software programs to look at your computer screen from a remote location, but I haven't tried this.  I just take Radarbox and the laptop with me when I go away.
I hope that this helps.
