Wrong path vector and airplane icone position
Started by Dana, January 19, 2017, 08:15:27 AM
Dana
has anyone experienced this:
Wrong path vector and airplane icon position. airplane icon and path vector is not moving in line with flight trail behind. In previous versions 3.13 and 4.03 this never happened .
Any solution to solve this problem ?
Thank you,
Dana
#1
I would think it would be a short time glitch which would eventually sort itself out, its hard to tell with the shot.  I presume that it does not happen with all aircraft.
It may be due to bad signal reception or bad output from the aircraft itself.
