airnav radarbox
Started by sergiomaria, February 04, 2017, 04:46:59 PM
sergiomaria
Hello Community,is there new software release for radarbox? Still on 6.0 here.
Thank in advance and good reception to the radio lovers.
http://www.airnavsystems.com/download/ANRB/ANRB60001Setup.exe from the support page Sergio but reports are that you would be better staying with what you have
Sergio, main issue is, that V6.01.000 doesn't remember your login data. So you have to enter it at every start of software. Aside to this fact I wasn't able to see any significant improvements to version 6.00.000. Therefor I suggest to stay with V6.00.000.
I downgraded back to V6.00.000.
N9JIG
#3
Are they going to fix the 6.01.000 release so that it saves the login info?
#4
Already done, please download:
http://www.airnavsystems.com/download/ANRB/ANRBUpgradeto600002.exe to update to Version 6.01.001
or download
http://www.airnavsystems.com/download/ANRB/ANRB60002Setup.exe
for full install. Don't forget to save/rescue your MyLog.db, Picture folder, silhouette folder (if you are using picture silhouettes), Logo folder if you are using full install and MyColor folder (if sustom setups are made). Further you should completely remove old install before installing V6.01.001. Remember: never install to destination programfiles always use something like C:\AirNav Systems\
Remark: The installer may give false information about what version is installed. The version I stated is installed anyway.
Regards Ingo
N9JIG
