Logs from sudo rbfeeder status
Started by DZpower, April 28, 2021, 11:35:59 PM
DZpower
can someone tell me what seems to be the problem ?
I noticed that my radarbox page is slow and not showing airplanes like on Piaware or FR24
I have a raspbery pie and have Piaware FR24  Radarbox and ADS-B exchange set up  under the RTL-SDR Dongle
pi@raspberrypi:~ $ sudo rbfeeder status
[2021-04-28 19:31:33]  Starting RBFeeder Version 0.3.5 (build 20200727132301)
[2021-04-28 19:31:33]  Using configuration file: /etc/rbfeeder.ini
[2021-04-28 19:31:33]  Network-mode enabled.
[2021-04-28 19:31:33]        Remote host to fetch data: 127.0.0.1
[2021-04-28 19:31:33]        Remote port: 30005
[2021-04-28 19:31:33]        Remote protocol: BEAST
Error opening the listening port 32458 (Raw TCP output): bind: Address already in use
[2021-04-28 19:31:33]  Error opening the listening port 32458 (Raw TCP output): bind: Address already in use
Error opening the listening port 32457 (Beast TCP output): bind: Address already in use
[2021-04-28 19:31:33]  Error opening the listening port 32457 (Beast TCP output): bind: Address already in use
Error opening the listening port 32459 (Basestation TCP output): bind: Address already in use
[2021-04-28 19:31:33]  Error opening the listening port 32459 (Basestation TCP output): bind: Address already in use
Error opening the listening port 32008 (Raw TCP input): bind: Address already in use
[2021-04-28 19:31:33]  Error opening the listening port 32008 (Raw TCP input): bind: Address already in use
Error opening the listening port 32004 (Beast TCP input): bind: Address already in use
[2021-04-28 19:31:33]  Error opening the listening port 32004 (Beast TCP input): bind: Address already in use
[2021-04-28 19:31:33]  System: raspberry
[2021-04-28 19:31:33]  Start date/time: 2021-04-28 19:31:33
[2021-04-28 19:31:33] [airnav_main]  Creating dump978 thread...
[2021-04-28 19:31:33]  Bind failed on ANRB channel. Port: 32088
[2021-04-28 19:31:34]  Connection established.
[2021-04-28 19:31:36]  Can't connect to 978 source (127.0.0.1:28380). Waiting 5 second...
[2021-04-28 19:31:41]  Can't connect to 978 source (127.0.0.1:28380). Waiting 5 second...
[2021-04-28 19:31:45]  Could not start connection. Timeout.
[2021-04-28 19:31:46]  Can't connect to 978 source (127.0.0.1:28380). Waiting 5 second...
[2021-04-28 19:31:51]  Can't connect to 978 source (127.0.0.1:28380). Waiting 5 second...
[2021-04-28 19:31:56]  Can't connect to 978 source (127.0.0.1:28380). Waiting 5 second...
[2021-04-28 19:32:01]  Can't connect to 978 source (127.0.0.1:28380). Waiting 5 second...
You are using wrong command, which starts 2nd copy of rbfeeder, and it cant find ports as these are already in use by 1st copy started by system and running in background.
Your wrong command:
First reboot Pi to stop 2nd copy.
Then issue correct command to see status of 1st copy started by system at reboot
The correct command is
DZpower
I did reboot the Pi and ran the 2nd command
is there anything else i need to check?
$ sudo systemctl status rbfeeder
   Active: active (running) since Wed 2021-04-28 20:33:09 EDT; 2min 36s ago
Main PID: 508 (rbfeeder)
    Tasks: 13 (limit: 4915)
           ├─508 /usr/bin/rbfeeder
           └─596 /usr/bin/python3.7 /usr/bin/mlat-client --input-type dump1090 --input-connect 127.0.0.1:32457 --server mlat1.rb24.com:40900
Apr 28 20:35:19 raspberrypi rbfeeder[508]: [2021-04-28 20:35:19]  Can't connect to 978 source (127.0.0.1:28380). Waiting 5 second...
Apr 28 20:35:24 raspberrypi rbfeeder[508]: [2021-04-28 20:35:24]  Can't connect to 978 source (127.0.0.1:28380). Waiting 5 second...
Apr 28 20:35:29 raspberrypi rbfeeder[508]: [2021-04-28 20:35:29]  Can't connect to 978 source (127.0.0.1:28380). Waiting 5 second...
Apr 28 20:35:29 raspberrypi rbfeeder[508]: [2021-04-28 20:35:29]  ******** Statistics updated every 30 seconds ********
Apr 28 20:35:29 raspberrypi rbfeeder[508]: [2021-04-28 20:35:29]  Packets sent in the last 30 seconds: 82, Total packets sent since startup:
Apr 28 20:35:29 raspberrypi rbfeeder[508]: [2021-04-28 20:35:29]  Data sent: 8.6 KB
Apr 28 20:35:29 raspberrypi rbfeeder[508]: [2021-04-28 20:35:29]  Data received: 1.0 KB
Apr 28 20:35:34 raspberrypi rbfeeder[508]: [2021-04-28 20:35:34]  Can't connect to 978 source (127.0.0.1:28380). Waiting 5 second...
Apr 28 20:35:39 raspberrypi rbfeeder[508]: [2021-04-28 20:35:39]  Can't connect to 978 source (127.0.0.1:28380). Waiting 5 second...
Apr 28 20:35:44 raspberrypi rbfeeder[508]: [2021-04-28 20:35:44]  Can't connect to 978 source (127.0.0.1:28380). Waiting 5 second...
lines 1-19/19 (END)
The status says:
Your settings for dump978 need to be modified.
(1) Have you installed dump978?
If yes, which one, Flightaware dump978-fa or Radarbox24 dump978-rb ?
(2) Please copy-paste output of following command
cat /etc/rbfeeder.ini
Note: remove you feeder key from the post.
DZpower
I do not have a second RTL connected for Dump978
just one Dongle
[client]
network_mode=true
key=xxxxxxxxxxxxxxxxxxxxxx
sn=xxxxxxxxxxxxxxxxxxxxxx
lat=xxxxxxxxx
lon=xxxxxxxxxxxxxxx
alt=110
sat_used=0
sat_visible=0
[network]
mode=beast
external_port=30005
external_host=127.0.0.1
[mlat]
autostart_mlat=true
[dump978]
#dump978_enabled=true
#5
This is strange.
Your file rbfeeder.ini has following line commented out (i.e. has # at it's start), so it becomes ineffective.
[dump978]
With above setting the rbfeeder should NOT try to connect to dump978, but your status shows it is trying to connect to dump978 and fails. This is strange and abnormal behaviour.
OK, ley us try to tell rbfeeder more positively that dump978 is not enabled by this way:
(2) Remove # from start of the line.
(1) change true to false
The line becomes like this:
[dump978]
dump978_enabled=false
(3) Save file (Ctrl+O) and close (Ctrl+x)
(4) Now restart rbfeeder, then again check status:
After few minutes:
