UAT Configuration for dump978-fa on Remote Device
Started by cseck1, February 27, 2021, 12:00:59 AM
cseck1
I recently upgraded my tracking setup from a 1090 MHz FlightAware receiver to an Airspy R2 running at 24 MSPS, which doesn't leave enough USB bandwidth to also run a 978 MHz UAT receiver on the same device. My solution was a second RPi running dump978-fa connected directly via an ethernet cable, which works for multiple feeders.
The easy, solved port issue: dump978-fa ports (solution: https://forum.radarbox24.com/index.php?topic=103271.msg444091#msg444091)
My current challenge is that I can't find a similar, undocumented option to set a dump978 host IP. Is there another configuration setting to direct rbfeeder to a dump978-fa instance on another device on the local network?
Or is the solution to use an SSH tunnel (or similar)?
cseck1
#1
Update:
I'm now running USBIP to port the UAT SDR's USB traffic from the second RPi to the primary with dump978-fa running on the primary.
My /etc/rbfeeder.ini file has the following config for UAT:
[dump978]
dump978_enabled=true
dump978_port=30979
When I look into the dump978-fa logs, I see a connection closing and reconnecting when rbfeeder is restarted and UAT traffic now on the RadarBox map.
Looking at  the later posts on https://forum.radarbox24.com/index.php?topic=103271.msg444091#msg444091 I note the last post states
If you're running piaware with dump978-fa and it is feeding FA UAT correctly, all you need to enable submitting your UAT feed to RB is edit your rbfeeder.ini config with the following:
[dump978]
dump978_port=30979
The dump978_port is detailed as 30979 not the 30978 as stated by you
cseck1
