ADSB Status Stopped
Started by Ldelaney83, November 14, 2021, 08:21:30 AM
Ldelaney83
Hi there
I received my Xrange2 the other day. I set it up inside my house just to test that it work. It picked up aircraft straight away. Today I have mounted the antenna and everything is connected properly. It shows me online but is not showing any aircraft, even though a heap have been going overhead. My status page says ADSB Stopped. I've turned it off for over an hour and restarted still doing the same. While I wait for support does anyone have any suggestions?
Cheers Liam Delaney
Double check the antenna connections at both ends.  Check the network cable connections at both ends, make sure any firewall is allowing passage
What lights are showing?
Ldelaney83
The cable on the antenna end i believe cant be removed. It is attached properly on the receiver end. I've tried different network cables and also the wifi function. The power light shows steady red. When a network cable is connected it shows an amber flashing light. I have it connected via wifi at the moment. It shows online and data packets received. But on status page adsb stopped. Very weird when it worked just the other day
Liam
Ldelaney83
No connection to Airnav and no temperature for the CPU doesnt look good so something is not working
I presume that they now allow users to connect via wifi as it previously required to be done via Airnav
When it worked previously did the power light show red, I thought that it should show green
Ldelaney83
#5
Yeah it was red when I tested it. The manual says red means powered on. Im confused how its picking up packet data but that adsb has stopped
Liam
no idea Liam, with zero degrees on the CPU temp it cant be working as it should be showing a quite high temperature and you wont see any aircraft until it can connect to Airnav's server and send its data back for display.  One of the developers will be tasked to look at it remotely so you will just need to bide your time until he does
Ldelaney83
All good..thanks for your time anyway Alan
Cheers Liam
