Deleting Alerts!
Started by nbquidditch, January 26, 2009, 10:28:06 AM
nbquidditch
Hey guys, I'm sure I'll get a quick answer on this? When I delete a certain Alert from the Alerts section they re-appear when I fire up RB the next time!! Am I missing something here? I'm obviously not removing them properly??
Cheers in advance.
This will only happen if RadarBox doesn't shut down properly - same effect if you put alerts in and they are not there when you fire up RB next time.
nbquidditch
Thanks for that I knew it would be simple. I've been closing RB by clicking the X in the top right. When I just tried File_Exit and restarted they'd gone!!
Cheers.
Fenris
Quote from: nbquidditch on January 26, 2009, 10:44:04 AM
Cheers.
The two things *should* be exactly equivalent, if they're not then that's a bug.
