First Impression
Started by Dan, September 08, 2007, 10:07:40 PM
Dan
Received my RadarBox 27hrs after I ordered it On-Line  .
Installed the software and connected the hardware and everything is running fine.
Congratulations to AirNav with such fine equipment and software . With the small antenna
in front of  my appartement's  window ( at 60ft Asl  ) tracking planes upto 100nm off.
See planes landing at EBBR ( Brussels) down  to +/- 3000ft at a distance of 60nm.
To the southwest I still track airplanes over Paris . My location is near Ebos Belgium.
Running the software version from the CD  . Will upgrade as soon as the official upgrade is released next week. Using Vista home premium.
Best Regards
Dan.
walfisch
Hi Dan, I have the same system, but much of troubles. Please can you send me a screen of your folder (overwiev). That can be for me a first help for solution.
Thank you very much and regards to Bruxelles.
Walt
walfisch,
If you are having issues, then try to upgrade to Beta 2 if you understand the details. Otherwise the release patch will be out soon.
Also contact support via email and ticket and tell us the details of the problems.
Dan
Walfish,
What kind of troubles do you have .What do You mean exactly with a screen of your folder ? Do you use the original version which came on the CD ?
Dan.
