number of flight
Started by charlie, May 12, 2009, 09:14:10 PM
charlie
Hello
What is a good number of flights to track?
Today between 0800 and 2200 local i had 1990 flights.
During the day I had between 80 and 140 flights displaying in 'My Flights' at any one time.
Is this good?
I am using a Watson antenna in the roof and live approx 40 miles NE of Stansted.
Yours
Charlie
malc41
Charlie
That's not just good its excellent
It would be interesting to see a polar diagram of your coverage
15 Miles East of EGNJ
Roof antenna , 40 miles from Stansted and around 2000 flights?
Wow! Lucky you Charlie!
As Malc says, your polar diag. would be nice to see.
daveg4otu
That is excellent ...nice to be somewhere flat.
Here at Torquay I am halfway up the N E  side of a 600ft hill facing into Lyme Bay...so the "view" to the S & W is a bit restricted.
Antenna is a MD1105 on a biscuit tin on Flat roof.
A good day ( only got  a couple of weeks to  quote from so far ) will produce  approx 1200 in   about 14 hours.
Today in atrocious weather (can't see top of bottom of hill- vis about 100yds)- 4 hour so far produced 734 contacts
Here is  polar diagram
charlie
hello
I put my Radarbox on 10 mins ago and have picked up 178 contacts
Here are a couple of screen shots
malc41
Charlie, want to swap homes!! ;-)
Your kit is working really well, is there something in the way to the south though?
charlie
I live a fairly built up area and wherever I move my antenna south is poor.
But I we are planning to move house to a smaller and less dense populated area and then the antenna will be outside on the roof.
This will hopefully aid my other hobby ham radio
malc41
Good luck with that, if you get the aerial higher and outside goodness knows what you contacts you will get.
Just out of curosity what aerial are you using?
charlie
It's a Watson I can't remember the model number but I bought it from Rocket Radio.
If you contact them I am sure they will tell you.
It was about eighty pounds
malc41
Thanks Charlie much appreciated
