Filter Help
Started by ukpbz, April 04, 2009, 10:44:42 PM
ukpbz
I am sure this will have been asked before so apologies. I did do a search but couldn't see anything obvious
I want to see only aircraft over 24000 ft.
I did the quick filter ok which filtered the list of aircraft but the map still showed everything. Can I filter on the map too?
Go into Advanced on the buttons and you can choose your altitude range to filter on the map.
ukpbz
