GAS update error
Started by b744, October 06, 2007, 06:25:28 AM
b744
Because of the system logic,if GAS has any incorrect data and you try and amend this,next time RB picks up that aircraft its data reverts to whatever GAS has.Think that makes sense!!??
Can a personal edit be made to override the GAS system ?
Rgds
It will only update the data if there is not data for that specfic Mode-S code in the first place. Hope that make sense :)
b744
All very strange ...
code 750147 GAS has as 9M-AFU A320 which is correct but the GAS function kept trying to enter details for 9M-FCL LJ60 and downloaded a very pic as well.
Likewise, picked up an old German code now used by an Indonesian aircraft, entered the correct details but it kept adding the German aircraft details and when I looked at the database there were 2 entries.
This is slightly at odds with what you say will happen...confused !
My only option has been to disable the GAS/pic function.
Should add that at no stage am I saying the data GAS have is incorrect in this case.
Rgds
