No Network flights showing
Started by dl1812, May 19, 2009, 12:05:22 PM
dl1812
Hi All,
Just installed ANRB onto my new Works Laptop (HP Elitebook 2530p)
Installed the software onto the D Drive, as per advice on this forum.
My Flights is currently showing 30-40 flights (about normal) but Network Flights is showing (0)
Checked that the "Get Flights" box is ticked of course.
It's counting down from 30 secs to Zero as normal, then it says"Network Flight Data Successfully updated"
It shows "54 Processing photo/info request(s)" in the bottom right corner (the actual figure is rising all the time).
I've checked that McAfee isn't stopping it.
Also, it's starting up quicker than before, but taking forever to shut down after File_Exit is used.
Any ideas ?
Dave
Your work laptop, does it connect to your works network.
It may be if that if you don't have a firewall blocking anything your laptop is connected to your works network via VPN and its not allowing to you to connect to other sites such as ours.
dl1812
Thanks for your fast reply - I'll check.
Dave
dl1812
Bingo !
Many thanks for that; off now to try and sweet talk our IT Man :o)
DaveLong
