Map Problems
Started by mdobuk21, July 24, 2009, 03:32:25 PM
mdobuk21
hi guys
does anyone know why my map settings do not save? everytime i start up the reverts to its original default (using v3.01)
Mark
Mark - do you mean the map location annd zoom, or the colour scheme?
For me, the map remembers its position and zoom, but often forgets which colours I chose last time, and reverts to Real Radar. The trick there is to rename your favourite coloyur scheme to Real Radar.mcl.
Hope thet helps
mdobuk21
hi Rod
what i mean is that my map doesnt save when i close down the program. When i return to start up my map reverts to the default map (world) instead of my home position!
cheers
Hi Mark
Once you have got the map how you want it, use the manu: Map...Open/Save... Save Map As... and name it Default.ml3
With any luck it will load that in future.
mdobuk21
cheers Rod, spot on!!
Mark
Jeremy
I have the same problem and have done the same but it still defaults back to Real Radar, but it does remember the map.
Jeremy
G4DOQ
QRZ.com
