BSTChart for RadarBox?
Started by Allocator, September 01, 2009, 06:57:07 PM
I've posted this on the Beta board as it might be considered 'sensitive' by SBS-1 users :-)  It might also be a function of the Beta software output.
There is a nice little routine on the Kinetic forum that reads the recorded .bst files to interpret and display the data.  I've contacted the author and he is interested in having a look at the RB rbl files to see if he can produce an RBLChart version.
http://www.kinetic-avionics.co.uk/forums/viewtopic.php?t=10562
I sent him a sample rbl file, but he has identified that there are data lines with the same time for the same aircraft, but showing slighty different information.  Here are a few lines I've copied from an rbl file I've just made.  His question of course is "Which line do I read?" which is a perfectly valid question.
$PTA,20090901165958203,AB5975,,23600,449.9,321.7,1728,,52.2819,-0.9335,,
$PTA,20090901165958203,AB5975,,23600,,,,,52.2827,-0.9345,,
$PTA,20090901165958203,AB5975,,23625,449.7,322.1,1792,,52.2834,-0.9356,,
$PTA,20090901165959437,4D2024,,36525,448.3,315.0,-3008,,51.8107,-0.1402,,
$PTA,20090901165959437,4D2024,,36525,447.6,315.1,-3136,,51.8124,-0.1427,,
$PTA,20090901165959437,4D2024,,36500,,,,,51.8123,-0.1427,,
$PTA,20090901165959453,400982,,13150,427.9,71.6,1728,,51.7226,-0.2659,,
$PTA,20090901165959453,400982,,13175,428.8,71.6,1856,,51.7229,-0.2647,,
$PTA,20090901165959453,400982,,13175,,,,,51.7231,-0.2635,,
$PTA,20090901170005765,A42297,,19925,,,,,51.9801,-0.5612,,
$PTA,20090901170005765,A42297,,19925,397.3,2.3,2176,,51.9808,-0.5610,,
$PTA,20090901170005765,A42297,,19925,,,,,51.9818,-0.5610,,
$PTA,20090901170005765,A42297,,19950,,,,,51.9827,-0.5610,,
Anybody have any ideas or observations here?
I've attached the extract from the rbl file I sent to the BSTChart author below.  He's highlighted some of the duplicates in green.
