Radarbox keeps closing!
Started by Smf_333, October 01, 2009, 05:23:31 PM
Smf_333
Hi All,
Can anyone help me with this. If I minimize RB & open Internet Explorer do do other things on line and then close the window, RB closes also shuting down the program! Or if i open another window on top of RB, then close it.
Every version I've installed has done this and now I've just installed v3.06 and it's doing exactly the same! Sooooo anoying!
Also I'd like to close the lower window in RB that shows aircraft height to give a bigger general map, i've seen sceen shots of this veature closed but I don't know how to do it.
All the best, Smf.
Hi - I can't help with your first problem, I'm afraid, but you can press function key F8 to close/open the vertical tracking window, or you can use the Map menu - the option is about half-way down.
Smf_333
