Real-time Network access after installing new exe
Started by Allocator, October 12, 2009, 06:49:55 PM
An observation that might explain why some public users insist that they are only getting the 30 sec update when they have subscribed to real-time?
I was running real-time Network data OK with an early version of Beta V3.06 (pre-public release.) When I downloaded the final version of V3.06, on initial run I got the AirNav information pane above the aircraft list saying that real-time data was available for purchase.  The Network indicator was green and counting down from 30 seconds and did not say real-time.  I double clicked the info pane and accepted the 'hide forever' tick box.  Checking Tools > Network account information, it showed me as subscribed to real-time.
I shut down RB normally, paused a few seconds and restarted and I got the Real-Time indication along with the Network green light and all was as expected.
I experienced exactly the same with Public Beta V3.07 on the desktop and followed the procedure above to get access to real-time Network data and 20 sec refresh.
Installed the new exe on the laptop today and sure enough, same again.  No problem, shut down RB and started it straight away, but no real-time data and only the 30 sec update.
Shut RB down again, paused for about 10 seconds and restarted RB.  All worked correctly, Real-Time and green indicator and 20 sec update rate.
I haven't got any suggestions as to why this is happening, although it seems to be something to do with the new exe 'expecting' the user not to be subscribed to real-time?
John Racars
As I told before this day my connection is gone. I informed AN this morning and got this:
Your support request ticket number is 60799.
Still waiting for any solution but NO network for me now; last week I payed € 50,-- ore more for a half year....
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
Also John, support gets back to you within 24 hours. There was no need for you to post 3 times on the forum :)
John Racars
Hi support,
All is clear to me now. Thank you for the help; all is working fine with me again.
I beg your pardon for sending silly messages to you yesterday.
13 NM East of EHAM
ANRB:
