3.07 Beta
Started by Mark07, October 22, 2009, 07:52:21 AM
Mark07
Guy's,
I am having problems with 'selected flights'.  The selected aircraft is only staying highlighted in white for a few seconds then disappears making it impossible to track a flight
pjm
This problem has been reported to AirNav before. Should be on their "todo" list.
Mark07 - as a matter of interest when your problem wih selected flight occurs, which of the MyFlights grid columns is your selected column?
eg. Aircraft, altitude, distance etc.
Fenris
Quote from: bratters on October 22, 2009, 08:42:13 AM
It makes very little or no difference to me which column is selected, whatever is highlighted will stop being highlighted after between about 2 seconds and roughly a minute.
Mark07
Hi Bratters,
I usually select with the Flight ID but have tried different columns to no avail!
I don't bother to select any columns now but just go with the default on start up. It seems to help with the freezing of the map situation as I've had not had that occuring since leaving well alone (fingers crossed) but makes no difference with regard to the selected aircraft deselecting itself from the map.
