Pan Map facility
Started by Dean, October 31, 2009, 07:58:15 PM
Dean
Hi AirNav users
I want to be able to track a particular flight say Munich to Manchester and have it remain at the centre of my screen with the map below following it.
This seems to work on hardware tracked flights but is very erratic on network (delay) flights.
Can it be used on the network?
I select a flight and then click onn the pan map with active flight icon - is this how to select an active flight?
Fenris
Quote from: Dean on October 31, 2009, 07:58:15 PM
Hi AirNav users
Yes, this usually works OK. As you say the map moves in chunks because the position updates less frequently.
