No Routes Showing
Started by gzerovti, November 07, 2009, 12:27:38 PM
gzerovti
Just got back on after waiting for 4 weeks to have my Radarbox returnerd after repair.
I have noticed that all seems OK now but there are no routes showing on any flights?
I am still with version 3.01 could this be the problem?
What version should I now have?
Terry
G0VTI - On the flight path to EGNM
Try the beta 3.08 version, you will need install 3.07 first.
gzerovti
Installed V3.07 Ok then went to your link to install v 3.08 and I get this message, "This application has failed to start because rb.dii was not found. Re-installing the application may fix this problem".
What do I do?
Terry
Fenris
Quote from: gzerovti on November 07, 2009, 01:10:32 PM
What do I do?
Terry
You need to *save* the new anrb.exe file over the old one, not *run* it when the download dialog box opens.
gzerovti
Tried to save over the old one but v3.07 still comes up?
Also have no photo download now? Is this the network problems?
It seems to be the already known network / Server problem, because my photo / info requests have counted up to almost 800 unfinished items. Plus the weather info request aren't proceeded either.
Like Neil and gzerovti, I've got exactly the same problem - I've tried saving the 3.08 exe to the Drivers file, with the 3.07 exe still there, deleting the 3.07exe.   I've not "run" the 3.08 exe.   Given it up as a bad job - sticking with 3.07 until this is resolved.
jannuh
Save the 308 exe to your downloads map.
Then copy the exe file to your RB map, overwriting it.
bearcat
This is what I do. Close down Radarbox and go to the AirNav folder and rename the old ANRB exe to ANRB307.Copy the new ANRB.exe(3.08) into the AirNav folder. Restart Radarbox and all should be fine. Done this with previous exe files without any problems.
Are you starting RB using the old shortcut to the old exe?
You shouldn't be able to if you have renamed the old exe though.
bearcat
Hi Allocator
My shortcut still points to the original location which contains the new exe file.
When I restart Radarbox 3.08 come up in the green start box and 3.08 showing on the main screen
Sorry, bearcat, I was in fact answering CoastGuardJon's problem - forgot to use the 'Quote' button - :-0
gzerovti
I have finally got v3.8 by copying as per the previos postings. Thanks for all the help.
Still no photos but probably the known network problems as already stated.
Terry
