Freezing again
Started by Jeremy, November 11, 2009, 07:35:36 PM
Jeremy
My screen has frozen again twice today with the MyFlights list getting bigger and bigger. This was after sorting by altitude and looking lowest up. It had only happened once since the upgrade. Could the nework outages have had something to do with it?
J.
G4DOQ
QRZ.com
That is strange indeed as you seem to be a lone voice. Does your title bar actually read 3.08 beta Jeremy?
As mentioned in your other posts, I would try if possible to use another machine to rule out your machine.
Bad memory, faulty PSUs can cause computers to freeze.
Jeremy
Bratters - yes. 3.08B. and Realtime.
Airnav - Yes. A new 4 core machine as I had trouble with the last one. It has been fine up to the last 2 days. It is definetly associated with the MyFlights list that doesn't seem to empty. Sometimes it re-runs once I click on the lists, one time it did not.
No reason to suspect memory or psu.
Running split screen with monotoring Internet on screen 1.
I will keep an eye on it but I thought it worth reporting.
J.
G4DOQ
QRZ.com
pcochrane12
ive just come in to find my system frozen been running for 3 days continually the only thing thats changed is i left the network on today i've a very unstable network connection at the moment is it possible this caused the freezing
thanks paul
