Which files to back up my Aircraft database?
Started by Blincodave, December 06, 2009, 07:36:18 PM
Blincodave
Which files do I need to back up of my 81k+ table of aircraft details?
Dave
If it is aircraft you have picked up via your antenna, then it is the MyLog.db3 file that you need.
It you want the main source database that is used to fill in the details in the aircraft lists and to populate MyLog, then it is the NavData.db3 file that you need.
They are both in the \Data directory.  I'd suggest that you back them both up.
ACW367
You should also back up any custom colourschemes or map settings you created from the MAP or COLOR folders and one of the DAT files is your polar diagram (Not sure which one).
besty
