Magnetic Variation
Started by homestea, January 05, 2010, 03:41:38 AM
homestea
I there any way to input a magnetic variation factor into Radarbox so that the headings called out for aircraft to turn to are accurately shown in the flight data fields.  It seems the software is set to true north.... Is this correct?
The compass radar rings can be a bit deceiving where i live;  the variation is 13 degrees!
Quote from: homestea on January 05, 2010, 03:41:38 AMI there any way to input a magnetic variation factor into Radarbox so that the headings called out for aircraft to turn to are accurately shown in the flight data fields.  It seems the software is set to true north.... Is this correct?
Don't be misled by what you see on the screen - the column on RadarBox labelled Hdg actually shows track, not heading.  I've given up trying to get this changed as AirNav have stated that showing the wrong label is "more helpful" than showing the correct one :-)
See www.airnavsystems.com/forum/index.php?topic=1716.msg13553;topicseen#msg13553 for a longer discussion on this.
Anyway, track is always relative to true north, anywhere in the world, which is why I guess is why the maps are thus oriented.
