filtering flight levels
Started by mdobuk21, February 03, 2010, 11:42:04 PM
mdobuk21
hi guys
is there a way of filtering flight levels or show as an alert, aircraft that are around 1000ft? this would be handy for my local airport (LBA) as most aircraft which use the airport are not on the map! cheers for any help
mark
Horsham Spotter
Hi Mark.
In MyFlights go to quick filters and then altitude and select or type 1000 and then press < and then select. You then only see in MyFlights all aircraft below 1000ft.
Hope of use
Steve.
3.1nm miles south of EGKK westerly App & Dep.
mdobuk21
Cheers Steve will try that later!
Mark
