Does the Airnav receiver pick up ground based transmitters?
Started by kevingab, March 02, 2010, 08:29:23 PM
kevingab
I tried to search for the answer for this, sorry if I missed it.
I know the Airnav receiver pick up the ABS-D from other aircraft, but is it capable of picking up ground based transmitters that are broadcasting TIS data?
Kevin
viking9
Hi Kevin,
Yes. If they within line of sight it will display them.
Tom
Tom
Bury St Edmunds, Suffolk UK
15 miles SE of EGUN
http://www.viking9.co.uk
Quote from: kevingab on March 02, 2010, 08:29:23 PMI know the Airnav receiver pick up the ADS-B from other aircraft, but is it capable of picking up ground based transmitters that are broadcasting TIS data?
TIS-B transmits on the same frequency as Mode S downlinks (1090MHz) so RadarBox will certainly pick up those transmissions - but does it decode them ?
AFAIK, both RadarBox and SBS currently only decode 6 of the ICAO downlink formats (DF4, 5, 11, 17, 20 & 21), whereas TIS-B uses DF18, so I don't think we'll see anything on our screens.
kevingab
Thanks guys for the quick replies.  I guess since the signals are line of sight there is not any need to decode them... unless you were in an airplane.  I was thinking of cobbling up a portable system to try it out in the plane.  I heard that they did away with the five minute lag, is that true?
Kevin
viking9
What would be the use of ground vehicles just having Mode-S?
When I had the network I regularly saw fire engines at Dublin Airport and ground vehicles at Luton and Stansted being picked up by other users.
Tom
15 miles SE of EGUN
Quote from: viking9 on March 03, 2010, 09:53:56 AMWhat would be the use of ground vehicles just having Mode-S?
Do you mean why just have Mode S and not ADS-B ?
Many airports nowadays have Advanced Surface Movement Guidance and Control Systems (A-SMGCS) which are hybrids using ground radar, ADS-B and Multilateration.
A vehicle which only has Mode S can still have its position MLat-ed, and fitting only a Mode S transponder is presumably cheaper than a full ADS-B fit.
radarspotter10
Kevin
[/quote]
hi Kevin.
Check here.
http://www.airnavsystems.com/RadarBox/order.html
FROM PAT.
kevingab
I think I need to clarify what I mean by a ground based  transmitter.  I am referring to the ads-b transmitters that transmit TIS-B from existing ground based radar to airplanes.  This allows you to see non abs-d equipped airplanes by sending the primary (skin paint) and secondary surveillance radar data.
Where I live on the Gulf of Mexico the FAA just installed a complete network of the ground based transmitters.
Thank you for the input.
Kevin
kevingab
Quote from: radarspotter10 on March 03, 2010, 10:49:47 AM
Kevin
hi Kevin.
Check here.
FROM PAT.
[/quote]
Thanks Pat!  Really looks like a nice system that will only get better as more planes are equipped.
radarspotter10
Quote from: kevingab on March 03, 2010, 02:44:14 PM
hi Kevin.
Check here.
FROM PAT.
hi Kevin.
I downloaded the
http://www.airnavsystems.com/download/anrb/403/ANRB403Setup.exe
the demo is great,  and getting rave reviews about the internet, 3d is about second on my wish list, my new car is first,  and of course paddy's day is coming up.
from pat
