Help
Started by southwest125, April 12, 2010, 06:05:52 PM
southwest125
On my radarbox antenna the small gold colored piece that stick out of the plastic stand, so i can screw the atenna in has gotten pushed down. How can I fix this??
Thanks,
Ben
If it is sticking out at all, use a small pair of "needle nosed" pliers to gently pull it out.
eggplant
Or get a longer threaded bolt, screw it in and then retract it ? Even if your bolt is not the exact same thread you could screw it in just a thread or so, and then retract.
