MyFlights list & Map freezing
Started by DaveG, April 25, 2010, 07:35:04 PM
DaveG
Anyone had issues with 4.03 in 2D mode freezing?
By that I mean after some hours the screen stops updating unless I do something within the program, like moving map or reorder MyFlights list.
On another issue, tried to do a forum search for "frozen", Freeze" or "Freezing" and it only seems to list result about "by", what's that about?
Cornwall, UK
Jeremy
Yes. I still have trouble when sorting MyFlights by altitude. It has been discussed before but I juust put up with it.
J.
G4DOQ
QRZ.com
I run 4.03 all the time now, although I mostly use it in 2D mode.  No issues with freezing, just as stable at 3.13, hence using 4.03 as my default.
abrad41
I am the same as Allocator
No Problems what so ever here
Andy
DaveG
Switched back to 3.13 to confirm no problem there or not.  (I do sort by Tracked column in both)
Cornwall, UK
DaveG
Okay 3.13 doing the same now :-(
Uninstalled, installed in different directory and not going to touch columns to reorder anything, lets see how long it lasts.
Cornwall, UK
No problem here, and I always sort by Altitude.
DaveG
Cheers chaps, I know chances are its not RB, but its one of these things I know will be a B&^ch to find and resolve.
its was working fine before I decided to give 3D demo a try on 4.03.  One good think, not got much hair left to pullout anyway, lol.
Cornwall, UK
orkney
Quote from: tarbat on April 26, 2010, 04:34:16 PM
hello
We used to sort by altitude but no longer do so because of this persistent problem (It happened about once a  day). We also don't think it is a computer problem since it has happened on three different ones and it happened on v2 and 3.13.
I would really like the next version to cure this since the sort by altitude was a very good feature to have anduse.
Andrew
I was one of the original moaners about sorting by altitude (pre 3.13) and I think I'm right in saying it was one the final problems solved(?) in the beta testing. I burnt some midnight oil myself testing various solutions.
Since the release of 3.13 l haven't had a murmur and I'm permanently sorting by altitude descending.
It would be interesting to know if those with an "altitude" problem also have trouble with any other categories?
DaveG
Well since reinstalling and not touching an column to sort by everything is running fine. (touch wood), will give it another hour and then try sort by tracked again.
On a side note, when I had 4.03 loaded I thought I noticed times were displayed as local, but on 3.13 its UTC can anyone confirm this or have I just imagined it?
Cornwall, UK
Jeremy
Quote from: orkney on April 26, 2010, 05:28:06 PM
hello
Andrew
G4DOQ
QRZ.com
Jeremy
AS I said above, I still suffer this. It has happened on more than one computer and on all the versions. I have to assume that something is crashing my computer but I know not what!
Intererested in your findings.
J.
G4DOQ
QRZ.com
